History Lesson
k1500chevy97
EDIT.... got this from a guy on MCT
Look what happens when a President gets elected in a year with a "0" at the end.
1840: William Henry Harrison (died in office)
1860: Abraham Lincoln (assassinated)
1880: James A. Garfield (assassinated)
1900: William McKinley (assassinated)
1920: Warren G. Harding (died in office)
1940: Franklin D. Roosevelt (died in office)
1960: John F. Kennedy (assassinated)
1980: Ronald Reagan (survived assassination attempt)
2000: George W. Bush ????????????
And to think that we had two guys fighting it out
in the courts to be the one elected in 2000.
You might also be interested in this! .
Have a history teacher explain this if they can?
Abraham Lincoln was elected to Congress in 1846.
John F. Kennedy was elected to Congress in 1946.
Abraham Lincoln was elected President in 1860.
John F. Kennedy was elected President in 1960.
Both were particularly concerned with civil rights.
Both wives lost a child while living in the White House.
Both Presidents were shot on a Friday.
Both Presidents were shot in the head.
Now it gets really weird.
Lincoln's secretary was named Kennedy.
Kennedy's Secretary was named Lincoln.
Both were assassinated by Southerners.
Both were succeeded by Southerners named Johnson.
Andrew Johnson, who succeeded Lincoln, was born in 1808.
Lyndon Johnson, who succeeded Kennedy, was born in 1908.
John Wilkes Booth, who assassinated Lincoln, was born in 1839.
Lee Harvey Oswald, who assassinated Kennedy, was born in 1939.
Both assassins were known by their three! names.
Both names are composed of fifteen letters.
Now hang on to your seat.
Lincoln was shot at the theater named "Ford."
Kennedy was shot in a car called "Lincoln" made by "Ford."
And here's the "kicker":
A week before Lincoln was shot, he was in Monroe, Maryland.
A week before Kennedy was shot, he was with Marilyn Monroe.
AND.....................:
Lincoln was shot in a theater and the assassin ran to a
warehouse...
Kennedy was shot from a warehouse and the assassin ran to a
theater...
Creepy, huh? Send this to as many people as you can, because
Hey, this is one history lesson people don't mind reading...
    DaleB
    DaleB
  • Who's Online   1 Member, 0 Anonymous, 1,171 Guests (See full list)
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
    • Sure about that? A degree wheel and a dial indicator would lower your degree of assurance in that statement. 😉    It why we have offset keys and dialable timing sprockets. Just say'n.... I've built a few and have never seen one "On the money".
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed, regardless of whether they are in warranty or not, or in the hands of the original owner or not. Why not updates as well, especially since some of those can be safety related also?
