Hey everyone, I know there are lots of threads on this but wanted some thoughts on this.
My truck is a 2002 Sierra 1500HD with the 6.0 gas motor.
Im getting the P0300 randon misfire code ad the knock sensor code(cant remember the code number for that).
Truck just had the following done:
New Knock Sensors (did this twice with brand new sensors each time) and knock sensor wire harness.
New plugs, wires, coils, fuel filter, fuel pressure regulator and new upgraded intake manifold gasket.
Cleaned MAF.
There are no vacuum leaks.
Everything was torqued to specs.
Im still getting the same codes after all of that.
The truck runs absolutly  perfect.
So after all that, the same codes are still coming up.
If it wasnt running well, I would continue to investigate the issue however, Im thinking of just ignoring my engine light on and leaving it all alone.
Thoughts?
Anyone ben through this and actually found the culprit to these annoying codes that dont seem to affect how the engine runs?
Thanks in advance.
Edited by hoorders
  • hoorders changed the title to Randon Misfire Code But Truck runs perfect
Have you reset the codes between fixes? That's when I usually get the P0300 codes. Once I get all the problems corrected the P0300 goes away.
  • Thanks 1
Cleaned MAF.
Thoughts?
Thanks in advance.
Did you use GM sensors and the harness?  Did you use the OEM intake gaskets?  GM plugs?
Edited by newdude
    Enduro73
    Enduro73
  • Who's Online   3 Members, 0 Anonymous, 1,049 Guests (See full list)
