Radix finally installed.
Well, finally made time to finish putting it in last night. I must admit that it took a little longer than I expected but it is sure a well put together kit. First start up and couldn't believe how quiet it was. Rechecked everything and went for a quick ride. WOW! A whine is all you hear from the blower under hard acceleration. For a 3/4 ton 4X4 crewcab, this thing rips! The acceleration puts my old 1/2 ton to shame. Can't wait to tow the trailer with it. The roads are a little icy so I didn't wind it out but it accelerates from 80k-120k very quickly. In 4 wheel drive I have to ease into it or it just starts moving at a 45deg. angle, but like I said, it is a little icy here (-20C) I will borrow my son's Gtech and try and get some accurate times. I think this is going to be fun.
