New 5.3L 2004 Suburban
Had to sell the DMAX and I am looking for quick relatively inexpensive ways to get a little more pop out of the 5.3L. Short of a Whipple, what has worked for others?
Thanks in advance.
Ive put a K&N intake, predator programming, msd wires, and iridium plugs on my 4.8L. The intake and programmer really seemed to wake it up with alot more throttle response. I thought the intake would help out top end but it really beefed up low and mid range, it really grunts now. I will admit my highway mileage has suffered a little but actually i end up averaging more now. I guess i get better around town than i used to.
Hi,
The easiest, most effecient way to wake up your 5.3 is to install a tune like Westers or Nelson. $ for $, either one of these tunes will give you more performance for the least amount of $. K&N's, Catbacks, etc. are all great mods but they don’t impact the performace as drastically as a tune.
You can get a Nelson tune for $425.
Nelson
    bellssn690
    bellssn690
  • Who's Online   4 Members, 2 Anonymous, 831 Guests (See full list)
