NEED HELP
I have a 2000 shortbed, 2wd, reg cab silverado with the 5.3. Driving home from work today my "service engine soon" light came on. I have autotap and hooked it up to find the code. It produced the code: PO446 which according to the autotap web site is the Evaporative Emission Control System Vent Control Circuit.
Any idea what this could be?
Any help is appreciated. I am hoping it is something small so I do not have to take it to a mechanic.
Thanks,
Mark
First, check if the fuel cap is loose. The DTC P0446 could be set for that reason.
Also check for incorrectly routed or defective EVAP system vacuum and vapour lines.
A defective fuel tank pressure sensor that does not correctly respond to pressure
or vacuum causes this DTC to set.
A malfonctioning or damage vapor canister could also be the cause.
Good luck
Stef
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
