I have a standard cab short bed WT. This is as far as I can tell the only model without the spoiler (building on chevy.com).
I want to get a camper shell but I have no idea if the camper will come with the 'cut out' for the spoiler.
If it did is there any way to add a spoiler to Fill in the cut out?
Frustrating to have to deal with this dumb design.
