Bizzare keyless entry problem
sincityZ71
From local news station:
News 3 has learned that thousands of Las Vegas residents are having problems with their keyless entry systems on their cars. It seems to only be affecting American made cars, but owners want to know why. News 3's Steve Crupi is digging deeper into this bizzare phonomenon, and will have a live report on News 3 at 5 and 6.
It is true. I was one of those people. d**n keyless entry system was dead as a doorknob this morning and most of the day. Had to use the key to open the door and such. Just started working again, around 445pm PST. Weirdest d@mn thing. So far no explanation for what is going on. Probably some secret military project at 51 :rolleyes:
I was going to say that they were probably test flying one of those alien ships again. :fume::D
LOL...Actually the Air Force has already come out denying that they have something to do with it. :D:fume:
Bloody thing isn't working again...ahhhh. Keyless for my dad's sierra isn't working either. :rolleyes: This is just getting annoying. I know it isn't hard to use the key, but I keep forgetting to lock my doors, it is habit just to hit the button.
Well after my last trip out there Randy, I know you have the means to unlock those doors should you leave the keys inside...though it might not be the prettiest. :rolleyes:
Mine wasn't working either. I had to go to McCarran to pick up my girlfriend and it worked fine under the garage but as soon as I got home, it wasn't working again.
Been off and on all weekend. :thumbs:
weird sh*t out here man.
Been off and on all weekend. :)
I hear ya. D@mn thing is still not working right. Glad to know I am not the only one though. :) This is getting old fast. :thumbs:
I agree, this is some weird ass sh*t :P
That is really weird.
We have days around here where nobodys garage door opener works. Happens 2 or 3 times per year. Never had my key FOB quit working though. :thumbs:
    DaleB
    DaleB
  • Who's Online   5 Members, 0 Anonymous, 1,381 Guests (See full list)
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
    • Sure about that? A degree wheel and a dial indicator would lower your degree of assurance in that statement. 😉    It why we have offset keys and dialable timing sprockets. Just say'n.... I've built a few and have never seen one "On the money".
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed, regardless of whether they are in warranty or not, or in the hands of the original owner or not. Why not updates as well, especially since some of those can be safety related also?
