Hey Everyone,
New to the forum. I am preparing to install a 3" Cognito leveling kit with 1" rear blocks on my 2024 Silverado 2500 HD. I can't seem to find torque specs anywhere, specifically for UCAs, front and rear shocks, and leaf spring U bolts. Does anyone happen to have these specs? I will be sure to post pics when the install is complete!
For the record, I went with the Cognito tubular UCAs, as I didn't have a desire to cut into my brand new truck, with Fox 2.0 front and rear shocks. I will be installing everything this coming weekend with an alignment Monday morning.
Thanks for your help!
I have all those torque specs in my service manual. Send me a message and I can create a pdf out of the pages and send them to you.
8 hours ago, cemem said:
The upper control arm bolts on your 2024 Silverado 2500 HD should be torqued to 140 ft-lbs. The upper ball joint nut is 81 ft lbs. For your Fox 2.0 shocks, the front upper mount nut torques to 37 ft-lbs, and the lower bolt to 100 ft-lbs. Rear shock bolts, both top and bottom, should be tightened to 74 ft-lbs. Leaf spring U-bolts should be torqued to somewhere between 120 and 140 ft-lbs depending on the size and grade—140 ft-lbs is generally safe for aftermarket hardware. Make sure to torque everything at ride height and double-check your U-bolts after about 100 miles
Kinda curious how you got these numbers. Sure doesn't match to my OEM service manual. Almost sounds like an AI response.
    Enduro73
    Enduro73
  • Who's Online   1 Member, 1 Anonymous, 926 Guests (See full list)
