For all you guys running components...
1. What is the maximum mounting depth for the speakers?
2. Where did you put the crossovers?
3. How hard is the install? Did you have to make anything or do they just "bolt in"?
I put mine right in place of stock stuff. I did have to make a bracket to mount the tweeters where the stock tweets were, for it has an oversized hole. Cant recall the depth, but I didnt have anyh issues.
I put my crossovers under the dash (not a fan of leaving them in the foor for moisture and rattle factors) I just ran 2 wires through the door, and tucked them under the dash with some zip ties, and the other is behind my glovebox I do believe..
Mike
I cut a hole in the inner door skin and recessed a small box into the door to hold the crossover there, but some dynamat on the back side of it and siliconed the holes for the wires....ya I know, a lot of work. Mounted the tweeters on the triangle pannels at the corner of the window.
I bolted my crossovers on the inside of the doors, at the bottom, close to the front.
I didn't have to do any fabrication to get my speakers in (MB Quart).
My stock tweeter mounts accepted my new tweets just fine. All I had to do was put two screws into each to secure them, as I didn't want them falling of like some people have had the stockers do.
Depth really isn't an issue, unless you are wanted to put some small subs in there. In which case you might have to space them out from the inner door panel, and cut on the outer door panel a little.
Thanks guys.
Three good responses in 20 minutes! That is why I keep coming back to this site!
I'm about to order some components, and I'm sure I'll be having more questions as I go to install them, so count on hearing from me again.
Thanks again.
If you need pics....I might be persuaded to pull my door panel back off and snap a few if you think that this might help.
I wouldn't be able to get to it until the weekend though.
    appletrav
    appletrav
  • Who's Online   2 Members, 0 Anonymous, 309 Guests (See full list)
