A friend of mine just got a 2000 ZR2 EX-Cab and wanted me to get the RPO Codes for him, are they the same listed on this site or where can I find them ?
I would PM yZR2k.  If he's not too busy out 4 wheeling and pullin' his pants up, he'll probably be able to help you.  Oh, or that Mervz guy.......
Hey man.
I decided that since I don't have anything better to do today ,besides buy a new belt so Digs will shut up  ;) ,that I'd go ahead and trace what I can find some info on.
Anyway,this is what I've been able to come up with so far:
Description
AJ1 WINDOW TINTED, DEEP, ALL EXCEPT W/S AND DRS
DK2 MIRROR O/S, LH & RH, REM CONT, ELEC, DEFOG, PAINTED
JC1 Not Found
QJJ TIRE ALL, 31XlO.50RlSLT/C BW R/PE ST TL OOR
VXS Not Found
AU0 LOCK CONTROL, REM0TE ENTRY
D55 CONSOLE, FRT COMPT, FLOOR
K34 CRUISE CONTROL, AUT0MATIC, ELECTRONIC
RSA Not Found
V73 ANTENNA, FIXED
AV5 SEAT, FRT BKT, HIGH BACK
EVA Not Found
K60 GENERATOR, 100 AMP
SLA Not Found
XJJ Not Found
A28 WINDOW, RR, FULL WIDTH, SLIDING
E24 WWR SIDE, CARGO, HINGED
L35 ENGINE, GAS, 6 CYL, 4 3L, CPI, V6, 90 DEG
SLM Not Found
X88 CONVERSION NAME PLT CHEVROLET
A31 WINDOW, POWER OPERATED, SIDE
E63 BODY EQUIPMENT, FLEETSIDE, PUBX
M30 TRANSMISSION, AUTO 4 SPD, 4L60E, ELECTRONIC
T61 LIGHTING, DAYTIME RUNNING
YC3 CONVENIENCE PKG, DECOR LEVEL 3
B30 COVERING, FLOOR CARPET
FE9 Not Found
NF2 EMISSION SYSTEM, FEDERAL, TIER 1
UPO Not Found
YD3 Not Found
B32 COVERING, FRT FLOOR MATS AUX
FF4 ARM, TORS BAR SPRING ADJ ©
NP1 TRANSFER CASE, ELECTRONIC SHIFT CONT, TWO SPEED
UP8 STEREO RADIO INSTALLMENT PROVISIONS
YD5 Not Found
C5A GVW RATING, 4900 LBS
FF5 ARM, TORS BAR SPRING ADJ (D)
NP5 STEERING WHEEL, LEATHER WRAPPED
or LEATHER WRAPPED, STEERING WHEEL AND SHIFT KNOB
U16 TACHOMETER, ENGINE
YD6 Not Found
C60 HVAC SYSTEM, AIR CONDITIONER FRT MAN CONTROLS
GT4 AXLE REAR, 3.73 RATIO
N40 STEERING, POWER, NON-VARIABLE RATIO
U73 ANTENNA, FIXED, RADIO
YJJ Not Found
DC4 MIRROR I/S, R/V, TILT, DUAL READING LAMPS
G80 AXLE POSITRACTION, LIMITED SLIP
PA3 WHEEL, 15 X 7, ALUMINUM, STYLED
VFS Not Found
ZJJ Not Found
ZM5 SALES PACKAGE, UNDERBODY SHIELD
6WK Not Found
ZQ3 SALES PACKAGE, DRIVER CONVENIENCE II
7WK Not Found
ZQ6 Not Found
ZR2 CHASSIS PACKAGE, HIGH WIDER PERFORMACE, 4 X 4
ZY1 COLOR COMBINATION, SOLID
1SC OPTION PACKAGE 03
1SZ Not Found
12H TRIM COMBINATION CLOTH GRAPHITE (H) (92)
12I INTERIOR TRIM, GRAPHITE (92)
50U PRIMARY COLOR, EXTERIOR BLUE WHITE (91)
I also emailed this to you incase you check your mail before the forum and if he needs any other of the codes,let me know and I'll see what I can come up with.
    Patrick Fergy
    Patrick Fergy
  • Who's Online   2 Members, 0 Anonymous, 731 Guests (See full list)
