help filling front differential??
I believe it takes 3.6 pints, however should I just fill it until its even with the fill hole, or should I put in exactly 3.6pints?
I'll be changing oil/filter in the meantime so I'll be back in a few to check for advice:)
thanks
I would do it that way,just fill it to the bottm of the fill hole...just make sure that the truck is on level ground...if you have to jack it up,jack both ends of the truck up as level as you can,be sure to use good jack stands if you do have to jack it up
I've just done this to mine, I used Royal Purple Max Gear. Owner's manual says it should be at the fill hole at operating temp, something like .25 in below fill hole cold. I just filled it to the top of the fill hole, went and got it up to temp, took out the fill plug and let any excess drain out.
    appletrav
    appletrav
  • Who's Online   0 Members, 1 Anonymous, 499 Guests (See full list)
