Sound System
Just picked up a very clean 93 3500 crew cab dually, Need some help with the audio system though. Stock system three out of four speakers work, I'm not into the big thump thump stuff but I do like GOOD CLEAR SOUNDS! A friend of mind suggested some Kenwood Excelon KFC-X468 4X6 to replace the stock dead players and adding an amp to drive them, also add two 8" sub-woofers and a amp, I'd like to keep the cost down but I understand you get what you pay for!! Any suggestions would be much appreciated!!
  • 1 month later...
I agree with you friend about replacing the factory speakers but I would go with infinity plates with a mid and a seperate tweeter, they sound awesome. The eights could give you alittle bass if that's what you are looking for, we did an install on a nbs dually with 4 jl audio 8"s under the back seat and it looked good and sounded great.
:flag: I could'nt agree more with ya, I just installed the Infinity Plates and they sound great. Now I just need to get the rest of the system together, Question, is it better to install the subs under or behind the rear seat?
thanks for your input!
That would depend, do the seats flip forward, and lay down flat? If so, I would suggest putting them behind the seat in order to keep your interior cargo capacity.
If they don't flip forward, I'd keep them under the seat, and put the amp in the protected space behind the seat.
That's my .02 anyway. :flag:
    Sothpaw27
    Sothpaw27
  • Who's Online   1 Member, 0 Anonymous, 504 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
