Common ABS Failures?
I was trying to get a feel for what the most common ABS failures that anyone has seen.  I have a Jimmy with a failure in the ABS and looking for a place to start.
Pretty much anytime you have your foot on the brakes and you hit a bump at the same time.
Mine skips for a fraction of a second and then returns to normal.
Mine, the ABS light is on, and the ABS does not function.  I have locked em up and slid by my driveway as a test.  So my ABS simply does not work.
My '92 S-10 Blazer is the same deal.  The brake light is on and the ABS does not work.  I have had three dealers look at it and none of them would attempt to fix it.  They said that there is no fix to them, after you put a new unit in it wil go out as soon as you slam on the brakes again.
The problem I have is not so much that the ABS is not functioning. (I am used to non-ABS brakes)  But, I just moved to Pennsylvania and they require a "safety inspection" after licensing the truck.  The ABS light may not allow it to pass.
I used to have the ABS light on as well.  They hooked it up to a computer and cleared it.  Hasn't been on since.  Might want to check into something like that.
    Brendan C
    Brendan C
  • Who's Online   1 Member, 0 Anonymous, 1,222 Guests (See full list)
