TrailBlazer Ext Shocks
Anyone thought their TB might be a little soft in the rear end? Thinking of adding some heavier shocks to help the ride. Driving this thing down the highway feels like riding in a boat. The ass end seems to move way too much. Could be due to the tires, but most likely due to the shocks and suspension. Anyone have any ideas or mods that they have made to their TB?
Thanks, Ranger
The ext does have stiffer shocks, mine rides nice and tight, when I corner, I almost get no body roll. Maybe you have a leaky shock? Like I said my ride is nice and tight.
    hotfish
    hotfish
  • Who's Online   6 Members, 0 Anonymous, 659 Guests (See full list)
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
