2000 NBS Tahoe Engine Noise
I have a 2000 NBS Tahoe LT w/onstar and I have an engine whine in the radio. It is most notable when using my pac audio input adapter w/ my roady, but i can hear it a little all the time. Does anyone have an idea as to why it is doing this? Or how to get rid of it? help it's driving me nuts!!
i'm guess that this is the stock radio? I haven't heard of people having this trouble with stock radios before. But, I know that a bad ground for the radio or amp if you have one can cause this. I've done some 'systems' and this is a common problem in them cases. The amp power wire is either picking up inter. from something close to it, or the ground is to small or doesn't have a good connection.
but in order the try better grounding the radio, you would have to take apart your dash :rolleyes:
If it is under warrenty, then I would probably stop by and see what they say.
    bellssn690
    bellssn690
  • Who's Online   2 Members, 0 Anonymous, 522 Guests (See full list)
    • This is a really late reply but I just found this thread. They won't sell the hinges. I've gone 7 rounds with them. Their solution is to buy a new cover. I'm about to buy a new cover and it won't be a Bakflip. It also won't be from realtruck.com.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
