Removing switches
:thumbs:
1. Remove plastic piece clipped over end of wires.
2. Unplug and remove wires by lifting plastic latches on the sides.
3. Push in plastic tabs on switch and pull out the front.
4. Lift plastic clip at top of remaining housing and slide off.
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,242 Guests (See full list)
