Just got some Denali Projectors.....
and they come with halos and it needs me to tap into the parking lamps....it says to tap into the negative and positive ....but im not sure which one is + or -....i was able to pull down the rubber casing on parking lamps but ther are 3 wires ....black blue and grey?? which is which??.....................by the way im new here and looking forward to hang out in this forum.....
thanks
snorider156
Welcome to the Forum :lol:
What year is the truck?
You could get yourself a repair manual (Haynes or Chiltons) they have BASIC wiring diagrams in them...w/out knowing the year of the truck...my best guess would be the black wire is the ground,the blue wire would be the turn signal,and the grey is the parking lamp...BUT you should double check them with a test light..
also stay clear of the corner marker wires or the halos will flash with the turn signal and if you have DRL's(Daytime Running Lights) stay away from those wires also................just a guess,better to double check w/a test light
yeah its a 2001 sierra 150.....i got some quick taps ...but im just tryin to figure out the diffrences.....ill go and check out those books...thanks..
I have the same lights, and if you go to google and do a search for Denali Projector Halo lights you'll see a bunch of different sights...or there's always Ebay.
    ar0517
    ar0517
  • Who's Online   3 Members, 0 Anonymous, 619 Guests (See full list)
