Dyno results!!! but had some problems too..
well, the moment we have all been waiting for! the results..
Keep in mind, not tuned, 8psi (vs 10psi), runnings really lean, engine not getting enough fuel, here they are...
Rear wheel hp: 329.5 @ 4800 rpm
Rear wheel tq: 381.8 @ 4200 rpm
not bad huh???
like i said the problems, it was running really lean. how the hek do i fix this??? the d**n fmu was all the way in.
also, the engine is not gettin enough fuel, how do i fix that, bigger injectors??? i'll post on these problems later, but gtg..let me know what u guys think, are these numbers accurate?
Aj
not bad huh???
Aj
Bigger injectors, bigger fuel pump, LS1Edit..... Should fix all issues
A/F #'s were very high!
about 18:1 @ 2800 rpm, then it wavers down to 11.5@ 5200 rpm. this run was done with the fmu turned all the way in...
i know this is not good, im going to try and find a fitting for the fuel gauge!
Aj
Of course once the injectors are at 100% duty cycle, no amount of tuning from anyone will help! Call Lyndon Wester at 1 888 Wester1, he can look up the injector flow rate vs your boost and tell you which injectors you need, even if you don't get a tune from him, he will still help!
Butch 02 Sierra Denali
Exactly.. In fact ANY Corvette LS1 motor using a supercharger Requires bigger injectors and this Starts out as a high performance motor.
It comes as no suprise that the Truck is Starving for fuel...
well, the guys on the other forums have told me there are no injectors i can use to upgrade on my L31...thats the biggest drawback on that motor...so im SOL!
Aj
nope, using stock injectors.... i don't think u could put 454 injectors in a 350..right? :troll:
well, i actually found out why i was running lean... the first pulls, the fmu dial was about 1.5 turns out, then the "tuner" turned it in, think he was richening it up, when in reality, he was closing the dial, meaning leaning it out. no wonder why it was soo freakin lean!!! but wither way, im going to try and find a guy who has a wide band O2 sensor so i can get this d**n thing tuned!!!! im kinda getting tired of this now...
Aj
Aj
you are right.. There is actually only one injector...
• SEQUENTIAL FUEL INJECTION (SFI) provides a high
level of performance. The centerpiece of the SFI
system is a single-disk injector that is connected to
eight individual valves with flexible lines. The central
injector controls the flow of pressurized fuel to
the valve nozzle in each intake runner. This GMpatented
system delivers significant benefits to
Suburban customers:
— Fuel delivery is precisely controlled for optimal
cylinder-to-cylinder distribution.
— Reduced thermal mass of the valves
(compared to conventional solenoid injectors)
provides quick hot-starts.
— Nozzle design and optimum location produce an
effective spray pattern that contributes to the
engine’s smooth idle.
— SFI’s modular design simplifies service; its central
injector can be replaced as a single unit.
DUH!!! I was thinking TBI, sorry!
I did talk to Lyndon about this and he says he has had some success tuning these CPI systems for blowers. He mentioned that one of the best things you can do is to get cool air into the intake and not hot underhood air.
not bad huh???
Aj
Do any of these links help....
This link shows an upgraded SFI to 8 injectors using a "Spider Setup"
http://www.pacific-audio.com/performance/m...ges/231640.html
This link talks about an injector upgrade for SFI from Whipple. These kick in after the rpms get past a certain point.
http://www.pacific-audio.com/performance-d...discussion.html
More on Raising Fuel Pressure
Go to this link and search for L31 Tons of info..
DUH!!! I was thinkinh TBI, sorry!
I did talk to Lyndon about this and he says he has had some sucess tuning these CPI systems for blowers. He mentioned that one of the best things you can do is to get cool air into the intake and not hot underhood air.
Don't feel bad.. So did I....
I did see that Jacking the fuel pressure to 80lbs (Supposedly the max that the stock system can take) and adding an FMU is sufficient...
I came up with NOTHING on self tuning like LS1-Edit....
Maybe Westers can custom tune for him..
    CaptainDad
    CaptainDad
  • Who's Online   3 Members, 0 Anonymous, 611 Guests (See full list)
