Pacesetter Air F/X intake
srx70024
Just put on my Pacesetter Air F/X on my 95 K1500 350. Overall I give it a 6 out of 10. The boot for the TBI does not fit very well. I'm going to try additional gaskets to seal it up a little better. There is no area to bolt the support bracket to that they give you either.
I wouldn't recommend buying one of these. I just couldn't justify spending the $300 for one of the FIPK from K&N. I thought the $100 for this product was a bit much.
Actually, I am just going to send it back. It really is a POS. I'll have to look for others.
:D
    Brendan C
    Brendan C
  • Who's Online   1 Member, 0 Anonymous, 1,065 Guests (See full list)
