damage quality check out
I have a 2002 tahoe that was in perfect condition until it ran off the road and side swiped some trees with the passenger side of the truck. Any suggestions on how to assess the thoroughness of the collision repair.
The road, on both sides, had a steep drop off that was lined with trees and driveways coming out perpendicular to the road with built up gravel. After hitting the trees, with the front corner of the truck, the passenger side was smeared to the rear end. One of the driveways was the next obstacle and the truck stopped with the underside resting on the driveway - front tires over the edge. The truck would not move from this position wheels wouldn't even spin with a moderate load on the engine. I didn't force it - just had it pulled out with a wrecker. This all happened under 35 MPH. I did see some liquid dripping from the front end I smelt coolant.
The collision shop said it was sheet metal damage - I'm concerned that there may be some "powertrain" damage. My plan is to drive it and listen for any unusual noises - any other advice?
Thanks
Certainly you knocked the front end out of alignment. If you smelled coolant, then you most likely damaged your radiator, or a cooling line. I would be concerned about steering linkages, A-arm mounts, tie-rods, ball joints etc... The reason I say this is because my buddy stuffed his 2500 Avalanche in the ditch this past winter, and it completely ripped the front wheel out from under it. There was very little body damage, but the whole front suspension was broken. This was a slow speed crash in a snow filled ditch with a 4wd 2500!!! Yours sounds a little harsher...
BTW, Welcome to the forum!!!
    appletrav
    appletrav
  • Who's Online   4 Members, 0 Anonymous, 410 Guests (See full list)
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
