Brake Controller Installation
:banghead: I have a 2004 Silverado with the towing package. I understand the installation of the pigtail to the truck. My problem connecting the controller (DrawTite 5100) to the pigtail. Any help on the wire connections?
Yes, I have instructions for both the controller and the pigtail. My problem is that the instructions do not exactly match each other. I have attempted to follow the directions and match up the wires but have been unsuccessful.
not to be a pita but...... If you buy a tekonsha brake controller you can order a GM wiring harness so, all you have to do is plug it in. Makes life easy.
I think you have to give us some more info.... what wires are on the brake controller?
On my '01 the colors from the pigtail don't match the colored wires on the controller. I just matched up the little tags that were attached to the wires.
Some people with '03 and newer trucks have had to switch one of the pins on the rear receptacle for some strange reason... Others have been fine... :banghead:
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
