'04 Tahoe Exhaust
Can you guys tell me which exhaust system would be best for my '04 Tahoe. It's a 4x4 and has the 5.3. I want performance, but with interior resonance as close to stock as possible.
Any suggestion would be appreciated.
I put the Gibson Stainless Dual Sport Exhaust - I was looking for a mellow sound, deeper than stock at idle but not loud - it is exactly what I was looking for. Cabin noise is slighly higher under hard accel, but in medium and cruising it is hardly noticeable in the cab.
    ballencd
    ballencd
  • Who's Online   6 Members, 0 Anonymous, 685 Guests (See full list)
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
    • $5.19 for regular...
