Transmission Troubles
I've got a 99 Silverado 5.3L with an automatic transmission. It's got a hard time shifting into overdrive. I had it serviced for a general tuneup/fluid change, and the problem is still there. Does this sound like a serious problem?
When you say "hard time", do you mean the 3-4 shift is hard, or it doesn't go into 4th gear? I'm assuming the fluid level is good...how many miles does it have?
When I say 'hard time' I mean that it slips numerous times before it shifts. If I get to the point where it slips and back off, and then hit the gas hard, it will make it by the slipping point just fine. I've got 102,500 miles right now.
Ugh, it's slipping. Could be a servo/accumulator problem, or possibly it's just worn out. If the fluid is full and the engine is operating normally, I would definitely get it checked out. Could be serious, or it could just be a matter of removing the pan and valve body and replacing some components there.
Has anyone else experienced this? What was the outcome?
  • 5 weeks later...
going to my third tranny 3rd gear pack is probably going dont change the fluid
did that had to replace tranny in two weeks .what happens if you only change it when it gets bad is the new fluid cleans the bands of the build up and everthing becomes loose and boom goes tranny.hope you get some some help or just replace it with a good rebuild make sure you get good warrenty as the dont always get built right
  • 2 years later...
got sorta the same prob....
01, 5.3, 4l60E, not even 70k on it... It has the usual "clunk" for P to D, but at 50 mph it hesitates or "chugs" until 55mph. powering though it like 0-60 (merging on to the interstate) is fine but casual coasting and sure enough it happens again, fluids fine, changed roughly 3mos ago, no codes showing, not sure of a course of action any ideas? :):crackup::crackup:
Most of the failures are caused by drivers backing up & slipping into drive while still going back wards. This causes unreal clutch wear and abuse of the planetary gears causing failure.
I notice most of that stuff but, the clunk from P to D or P to R is the slip yoke/U-joint clunking.
well, changed the ujoints roughly the same time as the trans filer/oil, had step father look at it and drove it as well, the "chugs" only happen after it reaches operating temp... so i'm still perplexed on the problem and a course of action, plus today when my stepdad drove i got a weird whine from the back...( had the slider open) .... so.... i'm batting a thousand right now... :)
  • 4 weeks later...
well...
got some advice from a friend working at local tranny shop chain so i changed shift solenoids. probelm was used dex/merc AGAIN had same prob last time i changed filter, so i used dex6, still has overdrive prob but runs like a champ otherwise.. but problem (shifting) still persists.. plan on keeping truck but kinda strapped for cash. any ideas?? :cheers::banghead:
    appletrav
    appletrav
  • Who's Online   2 Members, 0 Anonymous, 241 Guests (See full list)
