Stock S-10 Converion to Xtreme
My son has left me his S-10 for the next 6-12 months while he and his Marine buddies are deployed in Iraq. It is a stock 2wd, posi, regular cab '02 with the 4.3. He slid off the freeway and lost the lower front valence, bent the bumper a bit, and scraped the argent plastic in front. Since he wants to lower it eventually, I'm wondering what it would take to give the truck an Xtreme suspension and front end. Any suggestions or references?
I know you can get all the parts from gm. They even sell the whole suspension as a kit. I've seen it in there performance parts catalog. The body parts can also be bought through gm. I think that information can be found at gmgoodwrench.com.
With that being said, it would probably cost half as much to go with an aftermarket lowering kit and body kit. I'm sure others here will help with some company's names.
Here is a list of the GM parts for the Xtreme. If your son's truck has the ZQ8 suspension you've already got the suspension for the Xtreme. I think a leaf was removed in the rear spring setup on each side for the X to lower it. I'll have to check mine to make sure. But here is the complete parts list to make up the Xtreme
Xtreme Urethane Ground Effects Parts
15034744 Filler Plate (S-10)
15056110 Filler plate (Blazer)
15034723 Xtreme Airdam
15034715 Front Driver Fender Flare
15034716 Front Passenger Fender Flare
15034711 Standard Cab Driver Skirt
15034712 Standard Cab Passenger Skirt
15034713 Extended Cab Driver Skirt
15034714 Extended Cab Passenger Skirt
15034721 Front Driver Bed Skirt
15034722 Front Passenger Bed Skirt
15034717 Fleetside Rear Driver Flare
15034718 Fleetside Rear Passenger Flare
15034719 Stepside Rear Driver Flare
15034720 Stepside Rear Passenger Flare
15034727 Fleetside Rear Driver Skirt
15034728 Fleetside Rear Passenger Skirt
15034729 Rear Driver Step
15034730 Rear Passenger Step
Mounting Hardware & Fog Lights
Airdam:
16530308 Xtreme Fog Lights (2)
15755954 Headlamp Switch with Fog Lights
15036162 Right Upper Support Bracket
15036163 Left Upper Support Bracket
11516993 Bracket Nut (4)
15037586 Right Lower Support Bracket
15037587 Left Lower Support Bracket
11517803 Push-In Retainer (6)
Flares:
Cab Skirts:
15034750 Standard Cab Skirt Retainer (2)
15034751 Extended Cab Skirt Retainer (2)
15993201 Push-In Retainer (5/Side if Standard Cab, 6/side if Extended Cab)
Bed Skirts/Steps:
15034752 Front Bed Skirt Retainer (2)
15037588 Right Bracket Extension (Stepside)
15037589 Left Bracket Extension (Stepside)
15036164 Rear Skirt Retainer (Fleetside) (2)
15036166 Right Rear Skirt Bracket (Fleetside)
15036165 Left Rear Skirt Bracket (Fleetside)
15993201 Push-In Retainer (7/Side if Stepside, 3/Side if Fleetside)
ZQ8 Suspension Part Numbers
GM performance parts #12371217
(ZQ8 Suspension Package Components)
Includes the following parts:
Part Number Description. Quantity
15989671 Mount Bracket (Left) (1) <-----Frame bracket for rear sway bar
15989672 Mount Bracket (Right) (1) <----Frame bracket for rear sway bar
11515358 Bolt (6)
15989674 Front Jounce Spacer (2)
15654771 Front Springs (2)
22124808 Shock Absorber (2)
22124809 Rear Shock Absorber (2)
15981886 Front Stabilizer Bar (1)
15981887 Insulator (2)
15996780 Rear Spring (2)
15989675 Rear Jounce Spacer (2)
15957475 Rear Stabilizer Bar (1)
15697708 Clamp (2)
15697706 Insulator (2)
15152683 U-Bolt (2)
15697708 Clamp (2)
11508101 U-Bolt Nut (4)
15697702 End Link (2)
11508696 Bolt (4)
10255857 Nut (4)
26071296 Steering Gear (1)
15991079 Clamp (2)
15597425 Insulator Donut (4)
15697709 Clamp (Upper) (2)
rear hop shock and brackets.
GM calls it a "rear axle vibration dampner"
22064821 Dampner (1)
15997356 Axle bracket (1)
15697709 Axle clamp (1)
15152683 Axle U-bolt (1)
11514598 Nut (2) for U-bolt
15988458 bolt (1) through shock eye
11516073 Nut (1) for above bolt
15672933 Nut (1) for stud through shock eye
15981396 Washer (1) for above nut
15996718 Frame bracket (1)
11516328 Bolt (4) bracket to frame
15672911 Nut (4) for above nuts
    ballencd
    ballencd
  • Who's Online   3 Members, 0 Anonymous, 428 Guests (See full list)
