Mothers car products
Just finished waxing my truck.  Went over it with a clay bar first and I'll say I think they work pretty good.  My truck is white so the tar stains stand out on it.  I used to use a little WD-40 clean it up, then wax the vehicle again.  With the Mothers clay bar I didn't have to rub as much and a whole lot easier to clean up.  When spring rolls around I'm going to give Zaino a try, I've heard all you guys say how good it is.
Search for the Zaino threads in here.....it really lives up to all the advance billing and lasts a long time.....especially nice on darker vehicles...look at Mervz pix....
    ballencd
    ballencd
  • Who's Online   6 Members, 0 Anonymous, 716 Guests (See full list)
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
    • $5.19 for regular...
