Idle Bounce when engine warm
I have 1999 Suburban 2500 with the 5.7L engine.
When the engine is warm, I often get a bit of an idle speed bounce after sitting at a stoplight for a few seconds. The bounce lasts for a few seconds and then smooths itself out. It's worse with the A/C on, though it does happen even with it off. Any suggestions? There's no check engine light on, so I assume there's no codes to report.
Thanks,
Dan
It sounds like you could have a vacuum leak. The IAC (idle air control valve) will bypass a deturmed amount of air pass the throtle plate to compensate for varring engine conditons. If you dont notice it during cruise speeds, because there is no manifold vacuum present then this should send you in the right direction because mechanical efficency will make up for the problem. During idle, manifold vacuum is the highest so when you come to a stop the IAC could be trying to compensate for the extra air coming into the engine, which is not a measured amount and until it can cut or reduce the amount of air being leaked into the engine by closing off the bypass port in the throtle body, then you will get that condition. Hooking up to the OBD II diagnostic port and reading the IAC's voltage during a test ride would help pin point the problem. Hope this helps some. Good luck.
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,266 Guests (See full list)
