HT 383 and RAMJET pfi?
Hi new to this forum. My 95 K2500 is weak and ready for some lovin. I plan on installing a HT 383 and ramjet pfi system from the GM performance parts catalog. Any imput? Fuel pump no big deal but throttle and cruise cables might be tough. any info appreciated.
  • 1 month later...
I have talking to Street and Performance about the Ram Jet system on a 383 with AFR vortec heads and the works. They said that they are having trouble with it flowing enough volume of air. I can't see why unless you are running 7,000 rpms which you shouldn't with the bigger crank. I have read where the GM harness can be purchased, Hot Cam installed and head work or didn't vortec style heads used to make 430 hp on the 350 ci. If you are building a torque monster with reasonable horsepower, 383 Ram Jet is hard to beat.
What are you planning on using for the fuel pump?? Will it be an in-tank drop in?? Ive been trying to find the setup similar to Parish's intank by racetronix but can seem to find anything. ANY HELP???? Im planning on installing the 385 Fastburn set up with the updated new style heads and possibly an ATI ProCharger come spring.
    ballencd
    ballencd
  • Who's Online   6 Members, 0 Anonymous, 685 Guests (See full list)
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
    • $5.19 for regular...
