Best Place to Buy a lift kit?
Where is the best place to buy a lift kit? I want good quality but i dont want to spend a rediculous amount of money on a kit. I'm looking for around 3" or so all the way around. I also might get the "green keys" for the front I have been reading alot about.
I've been into modifying cars for a while so I know who are the good vendors and who are not but trucks are a totally different ball game. I'd rather ask here first than find out the hard way. Thanks.
Mike
well.. more money = better quality, personally, i would go with either a fabtech or a cst lift kit, you can crank the tbars if you want the extra 2 inches also. for a 3 inch lift you could get away with doing the new keys but you will need new shocks and no one makes them for a 3 inch lift or 2 inch lift, also a 3inch lift wouuld be too much for the torsion bars and all front end steering/ a arm geometries... another lift option is new spindles, combined with the tbars could give you about 5 inches and put a 3 inch block in the back so everything is level, a 3 inch body lift will also make bigger tires fit better, it hink those run around under 500 bucks, i think that would look nice with some 17 inch weld's and some 33's :D
edit: rcd makes some good lifts, also watch out for torsion bar extender mounts, they have to be able to pivot, or else they will break
Mike
4wheelparts.com or try to find a bds dealer in your area, I used bds for my jeep and its been great
    bellssn690
    bellssn690
  • Who's Online   1 Member, 0 Anonymous, 1,009 Guests (See full list)
    • This is a really late reply but I just found this thread. They won't sell the hinges. I've gone 7 rounds with them. Their solution is to buy a new cover. I'm about to buy a new cover and it won't be a Bakflip. It also won't be from realtruck.com.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
