warning flashers
Does anyone know of a webpage where I can get the part to make the front flashers flash like a strobe ? Our construction trucks have them and sometimes I take my own truck to work instead of theirs.
Try checking with local safety equipment companies or do a Google search on safety equipment to find some on-line vendors. you can get "wig-wags" to install for flahing your existing lighting. They are used on police and emergency vehicles.
as gixxer suggested, you would need a separate stobe power pack with, cable leads to the lights where you want to install the strobe bulb.
there are several strobe power packs avail, in 4,6,8 + outlets. depending on how many lights you want to have flash.
installation of the strobe bulb requires drilling into the lens housing, and the bulb is installed.
i suggest the strobes be placed in the marker lights/signal light locations so the headlights dont 'drown' out the flasher. also make sure you are compliant with any local laws concerning flashing lights and colors.
http://store.yahoo.com/sirennet/unstrobkit.html
(just something i came up in a search)
good luck
John
You can also always try calling me, I sell this stuff, and I am pretty good with it.
WWW.FIREBARN.COM
I personaly only work on Wed (9-1), Fri (12-5), and Sat (9-1). But I am the guy that does all of the purchaseing and priceing for it. Either call the store at 800-825-0911 on those days or e-mail me and I can help ya out.
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,179 Guests (See full list)
