Direct Hits Ignition
N900WM
I now have 8,000 miles on the direct hits ignition. I give it a 2 out of 10.
It's a snap to install. If you can change spark plugs you can install this mod.
I can say that I feel a slight improvement in throttle response. But there has been NO change in fuel milage. In fact, it's down if anything. And no evidence of a H.P. increase according to the G-Tech.
IMO not worth $260.
Thanks for the scouting. I've been thinking about this for a while and have not heard any comments on it. If it did not pick up any gas mileage, then the darn things don't work. I put the jacob coil and ignition system on my old '90 model 350 tbi and picked up a nice sitp feel and showed a 2mpg increase. I've learned that usually hp is directly related to mpg when it comes to ignition systems.
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,242 Guests (See full list)
