Duramax Glow Plug Questions
I was with my friend the other day in his cummins and i notice he had a light to tell him when to start the engine, i was wondering about the 01 and 02 duramaxs and also the 03 and 04's, i was curious if they had a light?
On mine the glow plug light is at the top left hand corner of the cluster. The light looks like a spring, you'll know it when you see it. It never comes on on warm days and it is on only for a few seconds during the winter.
2004.5 d/a cc 4x4 the glow plug light is in the lf top corner
does look like a spring when on but gm has the quick heat glow
plugs so no matter what if it comes on its only on about a second
    bellssn690
    bellssn690
  • Who's Online   5 Members, 1 Anonymous, 857 Guests (See full list)
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
