Recalibrate ABS Brakes?
Was reading up on a manufacturers site about adding helper springs and came across this issue in the FAQ's:
"Do the anti-lock brakes need to be recalibrated? "
"No. ABS brakes need to be recalibrated only when changing wheel and tire sizes."
Have any of you that changed to bigger wheels/tires needed to recalibrate your ABS systems? If not, have you noticed any difference in how the ABS operates?
Didn't know this was necessary when upgrading size.
gnutruk
If you go larger you should get some sort of programmer or get your computer reflashed to compensate since the tires will be spinning at a different rpm than the PCM was calibrated for. This will effect anything that uses vehicle speed sensors...the speedometer, transmission shift logic, abs, etc.
I went to 285/75R 16's from 265/75R 16's, and didn't notice any real change in my speedometer or shift logic though. It does seem like my abs isn't as sensitive as it was before, which I like because it was oversensitive to me.
I guess it depends how much larger you go.
I went from 265's to 35's, major difference. ABS was coming on all the time for no reason. Got my PCM reprogrammed by Wester's, no more ABS coming on. Although, I didn't notice much of a problem when I just went from 265's to 33's (285's). Chris
    bellssn690
    bellssn690
  • Who's Online   4 Members, 2 Anonymous, 831 Guests (See full list)
