Famoso Private Track Rental Day
12secSS
Guys, didn't know if this was the best place to post this, but ... I thought maybe some of you would be interested in this. Ignore the due dates, as we are past that, but we are looking to fill the 75 car limit. Please pass this along to others who may want to participate. Thanks!
http://www.n2sracing.com/famoso/
Come and join us at one of the fastest So Cal tracks around town for some side by side racing! Famoso Raceway is approximately 635' above Sea Level. The weather and Density Altitude should be perfect for some very fast ET, so become part of the action!
A minimum of 55 vehicles must be signed on by 11/01/2004. If we cannot meet the minimum we shall either cancel the event or move it to a later date. The field of entrants shall be capped at a maximum of 75 vehicles with no exceptions. Cut Off for the event will either be right on 11/12/04 or before the cut off if we should fill in the maximum of 75 vehicles. We are requesting that the registration be prepaid via PayPal. Refunds must be requested by the 11/15/04 as a deadline or there will be no refunds issued.
Gates will be open at 9:00am.
Racing is to begin at 10:00am to 4:00pm.
Rules & Requirements:
* The Event Fee for drivers is $100.00.
* NHRA Rules will be enforced.
* Must be 18 years old or older in order to participate.
* Drivers License & Proof of Insurance must be presented.
* NO Front Wheel Drive vehicles will be permitted for this event.
* Last call will be made at 3:45pm & the Track will close right at 5:00pm.
* There will only be 75 Tech Cards issued during the event for security purpose.
* Unlimited guest are allowed to attend the track but they cannot participate in the event if they are not registered.
www.PayPal.com
to pay via credit card : [email protected]
to pay via non credit card : [email protected]
Send me an e-mail with your full name & vehicle information once the payment has been sent. Once payment has been confirmed, your name shall be added to a list as a confirmation.
List shall be updated at the end of each day.
If you have any questions, please contact me via E-mail at: [email protected], CC: [email protected] .
Famoso Raceway
33559 Famoso Rd.
McFarland CA. 93250
Famoso Raceway is approximately 12 miles North of Bakersfield California
Once payment is made with PayPal, the participant shall be agreeing that this web site or any other web site linked shall take no responsibility for any damages or loses during the event. If weather shall be a factor in the event, it shall be moved to a different time frame.
    AidenVorpagel
    AidenVorpagel
  • Who's Online   1 Member, 0 Anonymous, 545 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
