Headlight Adjustment
I'd like to adjust the headlight aiming on my 97 Z71. I found the tork screw for the up/down adjustment, but can anyone tell me what adjusts them right to left?
Also, I put some high wattage bulbs in the low beams and they work real well, but now want to put some in the high beam but I'll be d@mmed if I can figure out how to get to them. Looks like sheet metal covers them on the backside. Is it necessary to remove the grill or anything??
Thanx for the help.
on the light on my suburban the front light assy . should come out by un screwing to screws i think they look like alen wrench heads on them if u unscrew them there should be two on top of each light take them out and the light should pop right off making it easy to switch bulbs .....
Just keep looking, there will be another hex screw head with a torx inset about 3 inches below the top of the radiator upper support near the outer side of the light. It will control the side aim. The previous post covers how to get them out, so you should be good to go. Good Luck
Outstanding! Thanx guys. The days are pretty short up hear near the Canadian border, so it'll have to wait till the weekend. BTW - I put in some 80 watt "blue dot" low beams. They are definitely brighter, but not like I thought they'd be. I put the same thing (80/100) in my m/c and I could really tell, but I think the blue tint might detract from the brightness. I've got 100 watts for the high beams. Any extra lite helps us old guys.
Thanx
    Brendan C
    Brendan C
  • Who's Online   1 Member, 0 Anonymous, 1,130 Guests (See full list)
