1999-2003 ABS issue FIX....hmmmm
While researching the issue with my brakes I came across this and thought I would pass it on. Sorry if it is a respost. I hear a lot of guys with NBS trucks complaining of the ABS issues.
I have NO connections AT ALL with this comapny and have never heard of this fix as my truck is a OBS.......just passing along a link I found.
http://www.modulemaster.com/gmabsrepair.html
Most ABS issues that I've seen and dealt with are not constant running ABS motors, but low speed ABS activation caused by wheel bearing wear issues.
just my :2cents:
I'm not sure if this product fixes my ABS problem, but whenever I hit a small bump, I think my ABS starts doing it's job. Is that the problem? I've heard other people that has the same thing.
-w
That's a real common problem, happened to my truck about a year or so back. I was driving along, the abs lt came on and I heard the pump running, stayed running even with the truck shut off. Long story short, I diagnosed it as a bad abs module, and my friend goodwill warranted it for me, I just had to pay the $250 deductable. The part alone was over $800! Well, from what I hear, eventually it will happen again due to a circuit that burns out after x amount of start cycles...when that time comes I'm gonna have modulemaster fix it for good. There have been a few posts about this in the past, but it's always good to bring things back around just in case anyone needs that info in the near future. Good link number9!
Alot of folks seem to experience problems with oversensative abs systems and abs coming on too soon. I think that alot of these problems can be traced back to debris on the abs sensor and reluctor ring, while worn and loose wheel bearings will also cause this condition.
    appletrav
    appletrav
  • Who's Online   2 Members, 0 Anonymous, 309 Guests (See full list)
