Mystery Noise w/ brake pedal
I have a mystery noise, It seems like when you fix one noise, another one sneaks up. THat should be no surprise being a typical GM. Initially I had the wheel shimmy so I re-greased the Intermediate Steering shaft. That worked.
At the same time there was a grinding noise coming from the front right. I jacked the right side up and checked the wheel, and oh man was it loose. Long story short, I had to replace the front right wheel hub assembly ($350 for part at dealer, as the part is not available at Discount Auto Parts, they tried selling me a 4wd hub). I figured since it was apart I might as well replace the rotors, since they were slightly warped. No problem, now the truck has new rotors and pads. THis solved the grinding noise.
Here is where the mystery comes in. When I brake, there is a slight bumb in the brake pedal. It kind of sounds like a duck, and you cannot hear it outside of the truck. It only makes the noise when I brake to 5mph. I can brake to 6 mph, then let off and reapply the brakes at 4mph and it will not do it. It does not matter how hard or soft you brake, you get the little "bump" bump" in the pedal when it slows to 5mph. THe noise isnt coming from the calipers but the pedal.
How can changing the rotors and pads and one of the hubs cause this problem? Has anyone else had such a problem with their pedal?
I didnt bleed the lines and I did check for air bubbles in the brake reservoir and there was nothing.
ANy ideas, I have done some searching on this and other forums and cannot find a similar symptoms out there.
ANy input would be appreciated.
Oh yeah, it is a 2002 Tahoe LS 2wd with 53,000 miles. It needs new tires, but I am positive this isnt where the noise is coming from.
Sounds like the ABS is pulsing (only once). Did you mess up the ABS wheel speed sender while working on the brakes?
I did get the sensor in properly, only thing is. I didnt replace the actual sensor, I just used the old sensor. I did clean it up real good, as I did not think it would make that much of a difference.
I was hoping that wasnt it, because I didnt want to have to take the wheel back off. It is pretty annoying though, so I may have to.
Thanks for the reply..
oh yeah, i should mention that the abs light has not come on at all, so i didnt think this was it.
Being late I dont have time tonight to change out the sensor, so I decided to take out the ABS fuse to see if that was it. Sure enough, I took the fuse out and the noise is gone. So tomorrow I will definately swap out the old sensor for the new one.
    bellssn690
    bellssn690
  • Who's Online   3 Members, 0 Anonymous, 905 Guests (See full list)
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
