4.3L questions
Hey guys,
I have a couple questions for you, so Im gonna go ahead and lay them out one by one.
-What forum do you high performance 4.3 guys hang out at?
-Who has added a custom exhaust?
I noticed the oxygen sensors are before the catylitic converter. So, gutting the cats won't cause any problems with the a/f ratio readings.
-What size tubing for the exhaust?
What is recommended for adding new piping up to the exhaust manifolds? I'd like to add a larger diameter pipe. Drill new holes in the pipe for the oxygen sensor to fit in? Any ideas?
-What program, or programming for '99 and '00 S-10's/Blazer w- the 4.3L? Hypertech the best out?
I think that's about all.
Thanks alot,
Kyle
Wester's does tuning for 4.3's, the few reports i've read have reported very good gains. I think if you go to the midsize truck forums, or forums for S10's and Sonoma's you will get much more info on the 4.3 than at the fullsize truck forums.
Try here http://www.chevytalk.org/threads/postlist....t=0&Board=UBB46
I had a Hypertech in my 98 Sonoma 4.3. Very slight gains in performance, I could hardly tell if it was in or not, and that was with the 93 octane setting.
  • 3 weeks later...
S10planet.com-- I lived there before i traded my 4.3 sonoma on my new truck. Quickly, I will tell you: Get a K&N FIPK, NGK Tr6 plugs, Taylor racing wires, throttle blade mod, hypertech pp3(for shift points, firmness, rev limiter, and top end--dont expect gains from dual fuel tuning,dont install it). I went from 16.80's to 15.70's with the above mods. The FIPK is a must you will notice the gain immediately.
S10forum.com is an awesome site, TONS of info for the 4.3 liter over there.
As far as performance, I've got a 91 4.3 TBI w/ a JET Chip, K&N Filter, and Spin Tech exhaust. It's not the fastest thing around but it's got some balls to it!
Spin Tech by far, is the best sounding exhaust for a 4.3, IMHO. Next to it would be the Hooker Maxflow. Spin Tech's mufflers sound awesome on smaller engines, and I'm very impressed with what it did for my 4.3, the sound is superb.
As far as pipe size goes, you CAN go with a " single, but that's the max for single. I've currently got a 2.5" w/ a 3" tip on mine, looks sweet and like Isaid, sounds awesome. 2 1/4" would be the max for a dual out.
If you would like I can send the clip to you via email. Just let me know!
Oh yea, with my JET chip and K&N, I noticed decent improvements all through the rpm range. And gained an honestmpg around town :crackup:
