I thought of you guys this morning.
Chev4Ever
This would be a cool mod for everyone to do to their truck.
I was on my way to work and I pull up behind an mid to lower 80's chevy truck.  Cool right, well wait before you say that.  Well I look down at his rear axle (no rear bumper) and (by the way the truck is dark blue) it is green.  No I did not spell it wrong.  He sprayed his rear end light green.  He even painted his shocks.  I pulled beside him and the ends of his axles were green to.  I have no idea what this guy was thinking.
There is an old Scout running around here that is painted in black and white Zebra stripes and his pumpkin cover is painted bright yellow with a smilie face on it.  I love it.
There's a guy around here with a early 90's ford ranger and the truck is nicely lowered *which isnt the problem* He had the ugliest wire wheels and the paint scheme had 3 different colours... Bright Green, White and Yellow It looks like he did his own paint job and the everything from the winsheild was green the cab was white and the box was yellow.. Its looks like the ugliest piece of **** that i have ever seen :)
Or there was a later 90's green blazer LT that lives about 20 min from my old place and he had yellow taillight covers, yellow rear window deflector, yellow decals everywhere, yellow vinyl strip over the front window, yellow grille inserts, and a jap scrap exhaust..  Just a little bit of more tastless garbage.. I know these are peoples vehicles and all, but if you want to make it eye appealing at least make it something that wont make someone throw up everytime they look at it...
    ChristopherDobson
    ChristopherDobson
  • Who's Online   1 Member, 0 Anonymous, 1,012 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
