05 1500 crew Z71
All you guys that have one what kind of mileage you getting and are you happy with the truck? I have an 03 1500hd crew cab and thinking about tradeing, what gear ratio did you get? Just trying to decide if it would be worthwhile to trade, I only get 9-10 mpg in town and 14 on highway.
Back before the weather started getting cold I could count on 16-17 in everyday open running. (hilly and curvy 2 lanes). On the open interstate with cruise set 68-70 I have gotten as high as 20.1, but usually around 19. I'm averaging around 15-16 now that it's colder. I have the 04 1500 Crew with 3.73 LS rear end. Truck has 5700 miles on it and only problem has been tranny that was 1 qt low on fluid and have had front end alignment for uneven tire wear. Of the three NBS trucks I've owned this one is by far the most well screwed together. Body seams are much more uniform and fewer squeeks and rattles. I truly loved my 01 that this truck replaced, but so far I hardly even miss it (except for the payment.) Good luck with whatever your decision is.
vroten :seeya:
