Yukon XL 2nd Row Seatbelt Question
Is there a way to keep the driver's side rear seat belt latches from 'retracting' back into the slots in the seat back?
Our son would be able to buckle himself in (in his booster seat) if they didn't retract. I thought about using a small block of wood wedged in between the latch and the seat back, but wonder if there might be a better 'fix'.
TIA
On my Tahoe (which should be the same) there is no way to keep it from re-spooling - If you pull it all the way out, it goes into child seat mode, in which once tighten up will never loosen.
I'm not talking about the belt itself, but rather the end it clips into.
Because the clip pulls back into the seat after the belt is unbuckled, he has a hard time rebuckling himself because he can't get the belt into the clip.
Oh - I see what your talking about now. My 2000 Tahoe does not have retractable buckles - just hang on about 6" of belt.
Can you get to the part that does the "re-tracking" I am sure its just some sort of spring loaded spool - maybe you can get a pair of wire-cutters and break the spring.
good luck.
    appletrav
    appletrav
  • Who's Online   2 Members, 0 Anonymous, 309 Guests (See full list)
