I'm having an issue with my 99 S-10 ZR2. I just recently had Rancho RS5000 shocks put on it last Monday. After that I noticed a ruff ride (which is common with these). I also noticed a new front end clunk on both sides, And the rear is fine.
Well, Turns out that the fronts were installed wrong and they had to be facing rod end down. I went back yesterday had it all taken care of with no charge since they messed up. I started driving home and holy mother of all suspension clunks!!! The clunk was 50 times worse than it was before. So I did some research and found this info-
RS5000 series shocks for Standard S-10 4x4-
Front-RS5123
Rear-RS5190
RS5000 series for S-10 ZR2
Front-RS5123
Rear-RS5124
Why does Rancho use the same shocks on a stock 4x4 and a ZR2 when there is 3" of lift difference?
With Bilstein shocks, They offer a set for stock S-10 4x4 and a seperate set for S-10 ZR2.
Obviously there is an issue with Rancho's part numbers. I also want to say that this nasty clunk did not start until after these shocks were installed. The ball joints (uppers and lowers) pitman arm, and idler arm were done 2 years ago and around 28,000 miles on them so far. They are MOOG brand so I know those can't be bad already.
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 1,137 Guests (See full list)
