Front Diff Fluid
This weekend I decided to change all the axle and transfer case fluids in my 01 Silverado and 01 Tahoe. They both have about 60k, and this was the first change for the Tahoe (dealer has worked on the Silverado 4wd quite a bit).
I did the Silverado first, and the amount of 'stuff' on the front diff drain plug magnet was what I considered normal. However, when I pulled the Tahoe plug, I was horrified by how much metal was attached. You couldn't even tell that the magnet portion is about 1/3 the diameter of the drain plug. I wiped it clean - it had the consistency of toothpaste - and stuck it back in only to pull more metal out! The 4wd worked before the fluid change, and it still seems to work just fine after. I will probably drain it again this weekend just to make sure I got everything out.
What do y'all normally see - a little or a lot?
if it's the first drain, a lot of shavings and metal particles are normal. after the first drain and magnet cleaning, however, the magnet should never be as saturated as the first time.
Mine was pretty nasty at 30K. I went to synthetic. Dealer said synthetic was deemed un-necessary because the majority of users don't use 4WD as much as they think. I do, so I did.
Did mine at 11500 miles and it was pretty clean. A little bit of shavings on the magnet but not too bad. Added Amsoil 80W90.
Did my rear at the same time and it was clean but the diff had some huge shavings from machining left in it. I did it again 17500 miles just to be sure I didn't have a problem and it was clean and no shavings on the magnet even after towing 1000 miles. I used the GM Synthetic Fluid 75W90 because I have the G80 option.
The synthetic is good for cold temperatures because of the lower pour point.
    appletrav
    appletrav
  • Who's Online   1 Member, 0 Anonymous, 434 Guests (See full list)
