probably moving to DC
8.1Texan
Texan-dont let the "bucktoothed Confederate flag wavin Redneck" scare ya- :banghead:
Virginia is a great place to live (notice i didnt say D.C. or PG MD)...I lived in Arlington,VA for 10 years before moving to NYC 3 years ago...the population has built up a little since then but not a whole lot.
there are parts of Alexandria i would shy away from late at night nothing too bad-ive had to drive thru them late before without any troubles...then again affordable house is another issue....you may have to move out into BFE ??? if not move to Long island and Ill sell you a house cheap-lol
Scott
well, dispite my username, I am currently living in pittsburgh, the land of NO highways, so it takes me an hour to drive 9 miles each way.
I don't think DC will be much worse.
as for price...I think my entire raise will be spent on housing. I am figuring it will cost me between $4-5,000 more per year to have comparable housing.
right across the street from the white house
Are you alone or bringing a family? Renting a room in far N.W. Washington or towards Bethesda is an option if you're alone. If you need a house don't even consider Prince Georges County even though the prices will be lower. Housing costs everywhere is extremely high, even the far suburbs. IMHO the traffic in Va. is worse than coming in from Md. but both trips are terrible. I spent my whole career working nights just to avoid it. I would suggest taking a few days down here to be sure you want to punish yourself like this.
just me, my dog, and my cat.
Oh i am definitely coming down...March 20 is my official start date, so I have 4 weeks to figure this all out.
Luckily I will have corportate housing paid for 30 days, so that gives me another month to find a more permanent home. but not many extended stay places allow pets...
it's tough, but it'll all work out.
The key question is how much time do you want to spend driving to and from work. If an hour to 1.5 hours (each way) is good then you can get out to the more rural parts of MD and Northern VA. Some parts of Montgomery County are good but pricey. Taxes are higher there than Frederick County.
I can drive to the White House vicinity in anywhere from 45 minutes to 1.5 hours. Time of day is key. I'd guess an average rush hour commute would be an hour (normal day no accidents). Disclaimer - It's been a while since I've made that drive. I'm close to I 270 and Rt 109 (Hyattstown on the map). I've made the trip in about 30 minutes but we won't go into that.
Bill
    DaleB
    DaleB
  • Who's Online   3 Members, 1 Anonymous, 1,539 Guests (See full list)
    • If there are updates/fixes you want, you could pay to have the updates applied by the dealer.
    • Hi all - my current truck is a 2022.5 1500 High Country 3.0. I bought the truck used last year. After doing some digging, I noticed that my truck's software is stuck on the original build from 2022. I have no available software updates. I talked to my dealer about this and they recommended not trying to force an update since the 36,000 mile warranty is expired. This is a big bummer since there have been many major releases since that have fixed small issues and improved speed/usability.   For reference, the current software build number is: full_gminfo37_gb-user 10 W158E-W164.4.2-QIH22B-563.3 158 release-keys Has anyone had a similar experience? Should I just forget about it and move on, or try a different dealer?
    • Sure. Buy it for me 🤣
    • Using zip ties but 2-3 they snap due to sharp edges. Just using a shoestring. Last longer. 🤣
    • I ordered the Snap On...waiting for it to come in later this week or early next week.   New front cover, new crank seal and new balancer are on. Water pump, pulley, fan, hoses, and plastics reinstalled. I can move forward knowing all my timing marks are dead on and the front engine is hopefully sealed better than it was. Take 2 with the water pump...trying high temp thread sealer on the lower bolts.   Rebuilt injector and new-new regulator is in, it looks like new. Top intake reassembled and all the bits are reconnected and snugged down.   Thinking about knock sensors again, I located both of mine and, there's your problem, Francis... The driver's side one is broke, plastic is bashed in, part of the wire is bare, and it appears to have been damaged like that for a long time. I saw the wire but didn't think anything of it. The knock sensor might not be my pulled timing issue, but it sure looks suspect. It must still be conducting, otherwise I'd expect a CEL. But perhaps with its sacred crystal inside exposed, jilted and dirty, maybe it's sending mixed signals. So I'm waiting for one of those and a new pigtail to come in. Pass side sensor looks good, except for the spark plug wire resting on it (!). The plug wires are healthy so it shouldn't be causing an issue, but I separated them and added zip ties to nearby looms to keep everything well apart.   So, I'm down to installing a knock sensor AND, oh, replacing the exhaust and cat. I actually think that's going to be fairly easy, it's all bolt-together, all new stuff from Walker is laid out on the shop floor ready to go. Hopefully have this thing on the road again for the weekend.   My luck? It will still be leaking oil, coolant, pulled timing, intermittent CEL for running rich, or it probably won't run at all -- because that's how this project has gone.   I've never worked on a vehicle so ...hurt? ...cursed? in my life. Everything has been effed with SO HARD, but I think...knock on wood...I've managed to undo all the backyard stuff and we're almost reset back to "just" an 80k mile, 30 year old Blazer.
