Is it normal......
When towing my 12' enclosed aluminum snowmobile trailer I sometimes smell trans fluid burning in my '98 Yukon. It seems to be shifting fine and not slipping but I'm nervous. Truck has towing package (trans cooler, engine oil cooler, etc.) and I've added a B&M shift firmness control to firm up shifts for less heat. Maybe the 3.42 gears are the truck's downfall??? Truck also has 132,000 miles, so maybe I'm on borrowed time with trans? Trailer weighs about 1500 empty and maybe about 3500 lbs when fully loaded with 3 sleds with full tanks of gas. Plus truck then has 3 guys and all their gear.
You more than likley have the 4L60E. This is a weak tranny and you are lucky to have gotten that much milage without any mods towing what you tow. I would suggest a shift kit to fix a few problems that you will see soon anyway and this will give you some more time before needing an overhaul. The shift kit redirects the fluid in a few places and increases the pump pressure as well as changing some springs that are weak anyhow. When was the last time you had a complete fluid change on the tranny? Another thing to do is look for tranny fluid leaks around your radaitor and along the lines to and from the tranny. If you have a leak, it could be spraying on the exhaust system or on the block and burning giving you the smell.
The B&M Shift+ I have is suppose to increase line pressures to firm up shifts, seems to work okay. I didn't think shift kits were available for this trans, I thought you had to buy a power programmer and manipulate trans through that since everything is computer controlled?
I change (not flush) trans fluid and filter every 30,000 miles. I know this does not get it all out, but a full trans service is recommended at 50K, so I figure I'm doing less fluid more often. It is also the HD trans with deep pan and larger filter too.
I will check for leaks too.
Do you tow in OD? If you do, the torque converter will cycle locking and unlocking and really heat up the tranny fluid. I have an Escalade cluster with a temp guage. When I tested towing in 3 vs OD, I found it ran WAY hotter in OD. 185-190 versus 210-225. Temps 200+ will cook your fluid over time especially if running dino oil.
Regarding your mileage...I agree you are fortunate. I also have 136K on mine and I tow also but I change fluid often. I run dino oil and in addition to every 25K oil change (filter every other change) I drain and fill the pan at every oil change (5000miles). It is easy enough with a drain plug and the fluid is always pretty fresh with 4 qts exchanged every 5K.
Towing can be murder on a 4L60E. Heck it's already maxed out in a stock truck IMO. These things were meant for passenger vehicles, not trucks. If you add any significant HP or beat on it too often, you are destined for problems.
Oh yeah, 3.42's aren't helping you either. Just more work for the tranny (work=heat). I've got 3.73's and that's even a tad tall for heavy towing.
Bish, I never tow in OD, only sometimes coast down the backside of big hills in the mountains in OD. I do use dino oil, thinking of switching to synthetic but at this point it might be too late. I hear adding something like B&M trans fluid helps out with slipping and keeping temps down. Anyone think there is truth to this???
Yes a shift kit that firms up shifts will help reduce heat as the shift occurs faster and less time for frictions to heat up as they are rubbung. Regarding synthetic, I would not recommend it for a stock tranny. I have friend that experienced slipping with Mobil 1 and it went back to not slipping after going back to dino. On a built tranny/motor, yes, not on stock IMO.
The reason your tranny is still working is probably related to your not towing in OD. My fluid smelled burnt after a towing trip in the mountains of Colorado. Changed it right after the trip and that was 80K+ ago.
Yes, you can change the way the tranny acts through electronics, however, it still has a mechinical valve body. The shift kits modify weak springs in the body and change the pump pressure, and in some instances reroutes the fluid for better control. If you get a shift kit, I would recommend getting the new piston to replace the plastic piston in the valve body. I installed the transgo shift kit in my truck myself, it took me 4 hours of being on my back, the one thing that I would have done different would be to replace the seperator plate at the same time. I would not suggest anyone doing this themselves unless they know a little about automatic trannys. When I installed mine, all of my tranny problems and codes went away.
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,117 Guests (See full list)
