REPLACING THE RUSTED DOORS ON A 1993 S15 JIMMY. ANYONE DO THIS? I HAVE THE TOOL FOR THE DOOR SPRING.....NEED NEW DOOR HINGE PINS AND BUSHINGS. I BOUGHT A SET FROM AN AFTERMARKET COMPANY AND THEY SAID THE PINS AND BUSHINGS ARE "UNIVERSAL" FOR FULL SIZE AND COMPACT TRUCKS / SUV'S. I DISAGREE. ANY INFO WOULD BE GREAT. THE LOCAL GM DEALER HAS THE REPLACEMENT PINS AND BUSHINGS BUT I WANT TO MAKE SURE I HAVE THE CORRECT ONES. ANY TIPS / TRICKS??????? WHAT IF THE NEW BUSHINGS DON'T FIT THE REPLACEMENT DOORS SNUGLY???? WILL I HAVE TO WELD THE HINGE HOLE???? :seeya:
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,242 Guests (See full list)
