Low Fuel light setting
Bill55AZ
Last time I got low enough on fuel for the indicator to come on, I went about 20 more miles before I got to a gas station. I managed to put 27 gallons into a supposedly 26 gallon tank. This is a 2002 1500 extended cab.
Is there a way to set that low fuel setting so that it comes on a bit sooner?
No, there is no "setting" for that light. It's programmed into the IPC.
If it's not coming on until you have less than a gallon of fuel left, then you're fuel sender is not accurate. What was the gauge reading when the light came on?
just a bit above the E, and went down rapidly after that. IPC means Instrument panel cluster?
Yes, IPC is the cluster. I'd say it sounds like the light is working as it should. As to whether or not your gauge is accurate in general is another question. You shouldn't be able to get 27 gallons into a 26 gallon tank. :cheers: Besides, if you could, you probably would have been pushing your truck to the pump, not driving it there.
The guy ahead of me made a great effort to drain the hose before hanging it back up. I guess he robbed me of that amount.
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,179 Guests (See full list)
