Golf Cart Mechanics
Friz
I have two golf carts at my house, both broken. I have a good bit of mechanical and electrical/electronic know-how, but these are kinda new to me.
1) 36 volt Club Car. the batteries are good (we replaced them about 8 months ago). One of the guys that was helping maintain it decided if he switched some battery cables around, we could run faster. No joy. On a full charge, it will run for about 100 yards, then it's dead. The coil/solonoid pack is really hot. It has the old 5 solonoid system/ I was told to change the whole pack, but that is about $ 100-150. I don't mind paying it, but I can't afford to throw money at it without some idea that I'm doing the right thing.
2) 1990 EZ-Go, 2 stroke. Won't fire, plenty of gas and spark, 60 psi compression. I was looking at the carb ($150), one tech told me to try a fuel pump first. He said it could be sucking fuel into the crankcase (vacuum operated pump) and up into the cylinder.
Any ideas? I am on a short leash with these from the wife. I know that they are valuable, so I can't trash either one.
On the 2 stroke 60 psi is not enough. Needs at a minumum of 100 and it will run even better in the 125 range. I would tear it down and check the internals.
I used to have a Club Car - had the same problem --- replacing the solonoids worked for me. ---- If you want more speed there are aftermarket stuff for that -- I've heard them called " turbo switches"
Good luck
    Sothpaw27
    Sothpaw27
  • Who's Online   1 Member, 0 Anonymous, 418 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
