Ultimate Pickup Truck!!
Where would you drive it around here?
I guess anywhere you want :cheers:
I could just imagine the look on my moms face when I pulled that thing into my driveway...err well park it over the whole neighborhood....she got mad enough with my 1500 :(
And for those of you complaining about your mileage:
I did some reading, in the water, these things have a range of 40 nautical miles.
That's 15 Gallons Per Mile (nautical)!!! :(:chevy:
But BBSilverado has a point, you wouldn't be running out of beer for a couple of days. :D
Cheers,
Derek
    hotfish
    hotfish
  • Who's Online   6 Members, 0 Anonymous, 659 Guests (See full list)
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
