Yesterday as I was backing out of a space, my steering column locked up, then my brakes did the same. My battery light also came on. I couldn't turn my steering wheel or push the brake pedal. After putting the truck in park and turning it off, I then started it back up. The truck has acted normal since then. I took it to the stealership, but the truck threw no codes, so they cleaned the throttle body and did nothing else. When they called to tell me to pick it up and tell me what they did, I told them I was still nervous, since this obviously happened for a reason. What could have caused this? Any ideas?
No idea right off, but I'll ask around. Seems like I remeber this happening to someone else a year or so ago. I've had my Blazer 5 years now and I've never had it happen though.
Did the engine die? If it's not running you have no power steering and no power brakes. Your description of what hapopened has me baffled. Sounds like you couldn't turn or stop but your Blazer was still running. That "is serious" it is also 2 seperate problems. Can you elaborate.
The engine never died. That is what is confusing me as well as anyone I ask. I couldn't turn the wheel or push the brake pedal at all. It wasn't like I lost power steering or brakes, because with effort, I could atleast turn the wheel and push the pedal right??? The wheel locked up, and I couldn't turn it at all, same with the brakes. What surprised me was that the truck didn't throw any codes. I figured it would atleast throw one since the battery light came on. Like I said, the truck was fine after I restarted it. Right now I'm driving my parent's trucks around except for going to school. I guess I'll have to take it to a mechanic who has the ability to fix trucks without having to see a code.
Do you have any after market alarms/stereo stuff? Maybe some wireing is tangled up under the dash? That's the only explanation I can come up with without seeing it.
After posting here, I got to thinking. I'm not 100% sure that the engine didn't die. I was focused on the steering and brakes that I didn't focus on the engine. I know I sound stupid, but I can't remember. If the engine did die, what could have caused this? Sorry for the bad info. Thanks alot for the help. BTW, no I don't have any after market stereo stuff.
Today I talked with a mechanic who is a family friend over the phone. He mentioned that it might have been an EGR valve stuck shut. He said this wouldn't cause a code to show up, and that if this ever happens again to lightly step on the gas. After stepping on the gas you should get power back. Does this sound like a possibility?
  • 8 months later...
My 94 blazer has done something similar to that a couple of times. What will happen to me is I will try to pass someone and when i let off the gas the pedal will immediately go to the floor, like cruise controll took over and went to full bore. And I can't stop it because at the same time my brakes will lock up, like I can't pushed them down at all. Only way I can stop it when this happen is put it in nuteral. The motor will tach and I get my brakes back. It's the wierdest thing, I should probably have it looked at sometime, but it hasn't done it in a while.
  • 4 months later...
I had this happen to me on a 93 blazer and it was chunks of carbon in the EGR valve which caused it to stick and I lost all vacuum till I cleaned the carbon out of the EGR.
Currently a 1998 Blazer owner
    Brendan C
    Brendan C
  • Who's Online   0 Members, 0 Anonymous, 1,071 Guests (See full list)
