Haven't really been around...
LikeaRock14
Just thought I'd drop in, been a while since I posted, or at least posted regularly. I see there's been lots of changes to the site, lookds pretty good :cheers:
I'll go browse the forums now :cheers:
Eh, to be honest the site really slowed down IMO, so I just browsed the others I'm a frquent poster on, and kinda forgot about GMTC. It seems like things have really kicked back into gear though. But hey, every forum has a slow time I guess :cheers:
    Dom Colussi
    Dom Colussi
  • Who's Online   3 Members, 0 Anonymous, 551 Guests (See full list)
    • *Your
    • I'd guess that it's because they are Mann-Hummel filters since about 2016, they own Wix and are mostly all made in China now.
